Dirt Rider . Net Forums
Dirt Rider . Net Forums (http://www.dirtrider.net/forums3/index.php)
-   Mods, Performance & Repair (http://www.dirtrider.net/forums3/forumdisplay.php?f=15)
-   -   Pro Circuit exhaust leaking oil (http://www.dirtrider.net/forums3/showthread.php?t=38720)
glee 03-02-2002 10:41 PM
Just bought a 1998 KDX 200 with a Pro Circuit pipe and silencer on it. It had a piece of oil soaked cloth zipped tied over the connection where the silencer connects to the pipe. I removed the cloth and the exhaust to see if there should be some type of gasket. Only found a 1/2 inch wide rubber ring on the outside of the connection - nothing inside. I tried a metal hode clamp on it, however, after a very short ride the connection still leaked gunk. Any ideas???
Senior KX Rider 03-03-2002 04:13 AM
Sounds like you need to do some jetting work
motometal 03-03-2002 04:27 PM
clean with brake cleaner (or solvent), apply silicone.
and, of course, jetting.
MikeT 03-06-2002 09:45 AM
Jetting, Repack the silencer and run Maxima SuperM at 32:1.:D
motometal 03-09-2002 09:11 AM
regardless of jetting, you will never totally eliminate spooge there if there is a leak.
Copyright 1999-2005 DirtRider.Net
